Activity › Forums › Zaxwerks › Animating depth scale from face of an object, not the centre
  • Animating depth scale from face of an object, not the centre
    Posted by Jaso Allen on May 7, 2007 at 6:49 am
    Hi there,
    This is probably bleedingly obvious, sorry if I’m just daft.
    Basicaly I want to animate a bar graph, with three vertical bars growing from “nothing” to their value out of a common decorative base object (box)
    I can set it up and get the 3 bars to grow by animating the Set Depth’s, but they scale from the centre of the bars, so instead of just growing upwards, they expand downwards through the bottom of the decorative base box as well.
    Just curious if there’s a way to set the anchor/centre scale point so they can scale from one of the edges, ie the bottom, as to only go up.
    http://www.hectorpro.com/barchart.jpg
    Thanks for taking the time to read this, I appreciate any ideas. Again sorry if i’m just missing something simple.
    Jason Allen
    Serge Hamad replied 19 years, 4 months ago 2 Members · 3 Replies
  • Serge Hamad
    May 7, 2007 at 6:54 pm
    Hey,
    No, it’s not so obvious. What you are asking for would be a great feature.
    Untill then what you could do would be to use a transparency map to eliminate the part of your bar that doesn’t need to show up.
    Here is a quicly done project for you:
    https://www.nyc-visual.com/Graf_Bar.sit
    Salut.
    Serge
    “InvigoMany” On sale here:https://www.nyc-visual.com
  • Jaso Allen
    May 8, 2007 at 7:14 am
    Hello Serge,
    You are a god, as per usual. Thank you very much.
    When I tried to open your example it says you’ve got a more recent version of AE. I was just wondering what version you’re using, as I tried to open it in both 7.0.0.244 and the CS3 beta. There appears to be no objects in the Invig effects.
    Sorry Serge. Thanks again for all your help.
    Sincerely,
    Jase
  • Serge Hamad
    May 8, 2007 at 7:43 pm
    Hey,
    Maybe the project got corrupted.
    I used AE 7.0.1 and Invigorator Pro 4.0.8.
    Here is a new project with AE 6.5: https://www.nyc-visual.com/Graphic_Bar.sit
    let me know how it works.
    Salut.
    Serge
