Activity Forums DaVinci Resolve Animating curves.
  • Animating curves.
    Posted by Sean Lennon on December 3, 2021 at 12:53 pm
    I want to animate the exposure of a shot using the curves. I’ve tried to keyframe the adjustment I make to the curve but it won’t register on the timeline at the right point. I am keyframing the color corrector in the keyframes section on a new serial node I created, but as I mentioned its not applying the adjustments at the points i make them. Its applying it globally to the whole duration of the clip.
    Glenn Sakatch replied 4 years, 9 months ago 2 Members · 1 Reply
  • Glenn Sakatch
    December 4, 2021 at 10:03 pm
    If you specifically need to work in curves, then maybe try razoring up you clip at each point you want to do a keyframe. Do a different curve on each individual clip, and dissolve between them.
