Activity Forums Apple Motion Animating control points
  • Animating control points
    Posted by João Cunha on June 1, 2012 at 3:56 pm
    Hi.
    I’ve animated a control point of a shape (a arrow in this case) but I can’t give ease to the animation through the keyframe editor. Is there any other way to do this? When I create the animation, I have 2 points in the keyframe editor (start and end) but they are represented in a straight line.
    Thank you.
    João Cunha replied 14 years, 3 months ago 2 Members · 2 Replies
  • Stephen Smith
    June 4, 2012 at 3:26 pm
    So when you select both points and right click on one the Bezier option doesn’t show up?
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • João Cunha
    June 4, 2012 at 3:55 pm
    No. I can find the option to change the curves to Bezier and to add eases. The problem is that despite the values of both points are totally different, when we take a look at the points animation in the keyframe editor, it is just represented as a straight line.
    Thank you.
