Activity Forums Adobe After Effects Animating around a mask path
  • Animating around a mask path
    Posted by Erik Thurman on February 11, 2013 at 6:02 pm
    I’ve been trying to figure this out for awhile with no luck, and maybe it can’t be done. What I’m trying to do is animate a shape layer to a mask path in such a way that it bends to the curve of the mask path as it goes around it. As it is now, the shape layer (in this case a rectangle shaped layer) goes around the path but stays straight/rigid as it goes around it. Orienting the layer to the path makes it follow a little more closely to what I want but it still doesn’t exactly. The best possible visual analogy I can come up with is: picture a snake slithering along the path and its body conforming exactly to the path curves. If anyone know of a way that this could be done I would be greatly appreciative. Thanks
    Ashish Gupta replied 13 years, 7 months ago 2 Members · 3 Replies
  • Ashish Gupta
    February 12, 2013 at 10:26 am
    Erik Thurman
    May be this is what u r looking for …
    https://forums.creativecow.net/thread/202/894620
    Using red giant’s path distort from the Text anarchy bundle does the what u r trying to achieve.
  • Erik Thurman
    February 13, 2013 at 4:59 pm
    I was hoping that there would be a way to do this without 3rd party plugins, seeing as red giant is a bit on the expensive side. Oh we’ll. thanks Ashish for pointing me to that, I didn’t know that plugin existed.
  • Ashish Gupta
    February 14, 2013 at 10:48 am
    NP Erik .. and yes i know red giant plugins are expensive but thats the only solution i could find to your problem …
    i m pretty sure there would be a way to achieve this with native AE plugins and some expressions …
