Activity › Forums › Adobe After Effects › Animating and Transforming a shape
  • Animating and Transforming a shape
    Posted by Ron Ortiz on September 17, 2009 at 7:28 pm
    Hi guys.
    I’m trying to figure out how to do a shape animation in After Effects, it looks very simple but I just can’t get it to work the way I want to. I’ve tried with masking but I couldn’t get the same move. Here’s what I want to do:
    I want to achieve the same animation where you see the shape of the text background make a turn doing a kinda “wormy” move and disappear off the screen. If it was a straight move there wouldn’t be a problem, it’s that turn that gives me trouble. Obviously I’m new at After Effects and I’m learning as I go, so if you point me to a tutorial or give me a quick tip I’ll greatly appreciate it.
    Thank you.
    Ron Ortiz replied 17 years ago 3 Members · 4 Replies
  • Erik Waluska
    September 17, 2009 at 7:59 pm
    Search “Text on path” in the After Effects tutorials section and you’ll find several tutorials on this subject.
    -E
  • Dave Johnson
    September 17, 2009 at 8:33 pm
    The basic steps are to create a mask/path with the pen tool, apply the Path Text effect, then animate the margin.
  • Ron Ortiz
    September 17, 2009 at 11:41 pm
    Hey thanks for your answers! I got to animate the actual text, by making it follow a path, but I can’t get the shape behind the text (the orange shape) to follow the same animation.
    But I got the text to work, I’m making progress.
  • Ron Ortiz
    September 18, 2009 at 11:30 pm
    Thanks for your answer Dave. Someone suggested me using 3D stroke from Trapcode and works great, also using Effects/Generate/Stroke also works, animating start and end simultanously.
    Thanks to everybody for the help.
