Activity Forums Adobe After Effects Animating an eletricians floor plan
  • Animating an eletricians floor plan
    Posted by Martin Eriksen on July 17, 2012 at 3:06 pm
    Hey Creative Cows out there! I’m doing a “simple” animation for a TV Show. It’s about an electrician, and they want the floor plans of a floor animated to a dummy voice saying “First we’ll isolate the walls, but up two walls and some doors”. ANd they want the whole thing animated.
    I got the PDF of the floor plan, I separeted the individual layers in Illustrator and brought it into After Effects. But it’s like 70 layers for THIS ( https://cl.ly/image/012h1T351E0E ) little sketch, and they’re planning to give me more of them over the following winter.
    So I need a smooth and stable way of generating the animations necessary for approx. 25-50 different animations. Does anyone have ideas? I’ve been thinking of the Stroke-effect, but that will take hours, and I am paid for like 2 hours for each animation, so I wouldn’t like to go over my schedule as I’m a film student and have a busy schedule in school as well.
    Thanks in advance!
    Martin
    Martin Eriksen replied 14 years, 1 month ago 2 Members · 2 Replies
  • Dan Fredley
    July 17, 2012 at 5:11 pm
    One way is to copy and paste the illustrator paths as masks onto a solid. (I would suggest setting the AICB preference to “Preserve Paths.”) Use redefinery’s “MasksToShapes.jsx” script to convert them all to shapes. Apply a white stroke. Then apply a trim paths animator and change “Trim Multiple Shapes” to “Individually.” This might not be exactly what you want, but it’ll get you to a good starting point. Then you can reorder the paths and group them into sections as needed.
  • Martin Eriksen
    July 18, 2012 at 6:25 pm
    I found a way after about an hour googling through options. But you had a few tricks up your sleeve I havven’t tried out, so I will!
    Thank you very much, Dan!
