Activity Forums Adobe After Effects animating a train in AE
  • animating a train in AE
    Posted by Dab@hyperactive.to on January 25, 2006 at 12:42 am
    assuming I have a series of layers arranged sequentially on the screen to form a train and I only want to animate the front car and then have all the other cars follow the same path, what’s the proper parenting or expresssions I need to set up between cars (i.e. layers) for this to work?
    Joe Chao replied 20 years, 8 months ago 5 Members · 4 Replies
  • Mike Clasby
    January 25, 2006 at 12:55 am
  • Filip Vandueren
    January 25, 2006 at 3:40 am
    The problem is that if your ‘locomotive’ stops; all the layers would come crashing into it. 🙁
    The easiest solution that springs to mind would be to precompose all your layers using the ‘follow the leader expression’, do the motion of the loco in constant speed, that way all the wagons will keep the right distance from each other.
    Then use time-remapping on the pre-comp for slowing down, reversing, stopping etc.
    But perhaps there’s still a more logical approach that would let you just animate the loco-layer.
  • Dan Ebberts
    January 25, 2006 at 4:59 am
    The last three examples on the page that yikesmikes referenced keep the “cars” evenly spaced. No crashing. 🙂
    Dan
  • Joe Chao
    January 25, 2006 at 7:45 am
    Maybe you can try Trap Code’s new plugin:3D echo.
    It might work in your case.
    I love After effects!
