Activity Forums Adobe After Effects Animating a single character.
  • Animating a single character.
    Posted by Mohammed Ovais on April 26, 2010 at 11:22 am
    I tried the search engine, couldn’t find anything on this, strange since I thought it would be commonly used.
    The problem is, I haven’t used AE in a while so I’ve forgotten how to animated a single letter/character in a text layer.
    What I’m trying to achieve is just to rotate the first letter of two words only and not the entire words.
    I know there is a very quick way of doing this, could you guys remind me?
    I tried messing around with offset, start and end, also range too, but it just doesn’t work, maybe I’m not doing it correctly.
    Mohammed Ovais replied 16 years, 5 months ago 2 Members · 3 Replies
  • Mohammed Ovais
    April 26, 2010 at 12:02 pm
    Just to go into a bit more detail, the words I’m going to be animating are This July. One text layer which is “THIS JULY”, that’s when the event is, I want the entire text layer to fly in, but as it flies in, I only one the letters T and J to rotate, the direction doesn’t matter much, but I just want T and J to rotate. What would you suggest?
  • Michael Szalapski
    April 26, 2010 at 1:39 pm
    You will want to animate rotation and use a range selector to only select the letters you want to move. This tutorial and this one may help with that.
    Or simply read this.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Mohammed Ovais
    April 26, 2010 at 2:00 pm
    Thanks a lot mate, very much appreciated.
