Activity › Forums › Adobe After Effects › animating a signature tutorial question…
  • animating a signature tutorial question…
    Posted by Jpminibike on July 7, 2005 at 6:29 pm
    In Kevin Kantorski’s tutorial about animating a signature I am having some issues.
    When I copy the pen drawn outline. After Effects will not allow me to paste it in the composition under write on. The Edit/paste is just not a selectable option. Did I do something wrong?
    Chris Smith replied 21 years, 2 months ago 2 Members · 1 Reply
  • Chris Smith
    July 8, 2005 at 2:37 am
    Don’t know the tut, however make sure you are copying from a selected parameter so the keyframes are copied to the clipboard buffer. Then in the write on effect make sure you select a parameter first then paste the keyframes.
    Chris Smith
    https://www.sugarfilmproduction.com
