Activity Forums Adobe After Effects Expressions Animating a property over a specified time
  • Animating a property over a specified time
    Posted by Klemens Hertha on April 15, 2013 at 2:54 pm
    Hi!
    I wasn’t able to find anything here or on google, but this should be really basic and easy… Maybe you could help!
    I have a lot of pitures (3d) in a comp which are not animated on their own. A camera moves backwards and the pics with different z-values “fly away”. All I want to accomplish is that when a picture reaches a certain distance to the camera, it should begin scaling down to 0 over a certain amount of time, let’s say 2 sec.
    The expression I’ve got right now is this one:
    startScale = [100, 100, 100];
    endScale = [0, 0, 0];
    distance = thisComp.layer(“Camera 1”).transform.position[2] – transform.position[2];
    if (distance > (-12000))
    {startScale}
    else
    {ease (time, in_point, out_point, startScale, endScale)}
    Works, but 2 problems: Now the scale-value stays at 100% as it should but when the layer reaches the specified distance to the cam it jumps to the value which it has at this point in time! I want it to smoothly scale down from 100 to 0!
    Second is that I don’t want to use the layer in- and out-points as tMin / tMax. tMin should be the frame where the specified distance is reached (how do I convert that in time??) and tMax 2 sec later!
    Thanks in advance!
    Klemens Hertha replied 13 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 15, 2013 at 3:54 pm
    Distance triggers aren’e simple. You have to go through the timeline, frame by frame, to find out how long it has been since the threshold was reached.
    Something like this:
    startScale = [100,100,100];
    endScale = [0,0,0];
    threshold = 12000;
    p2 = thisComp.layer("Camera 1").transform.position;
    p1 = transform.position;
    fCur = timeToFrames(time);
    f0 = timeToFrames(inPoint);
    t = inPoint;
    for(i = f0; i <= fCur; i++){
    t = framesToTime(i);
    if (Math.abs(p1.valueAtTime(t)[2] - p2.valueAtTime(t)[2]) > threshold) break;
    ease(time-t,0,2,startScale,endScale)
    Dan
  • Klemens Hertha
    April 15, 2013 at 5:26 pm
    Thanks again, Dan! Works!
    Although I don’t understand this one anymore… 😉
