Activity Forums Adobe After Effects animating a moving line
  • animating a moving line
    Posted by Ben Weller on July 27, 2009 at 5:17 pm
    hi everyone,
    i am currently working on an animation in AE using masks to create the shapes that i need, but the only problem is, i eventually want to go over the top of these and create an outline, that i can keyframe to follow the shapes.
    is there a way to, say, draw a line with the pen tool, then keyframe the points of that line, so that the shape of the line changes over time?
    any help with this would be amazing, as its the only thing im not sure how to tackle with this animation. im sure its probably quite an obvious thing, but never having had to use AE in this way, im finding im learning a lot of new stuff.
    Thanks a lot in advance,
    Ben.
    Ben Weller
    http://www.keywoundmotor.co.uk
    Todd Kopriva replied 17 years, 1 month ago 4 Members · 3 Replies
  • James Henley
    July 27, 2009 at 6:53 pm
    Hi Ben,
    If you want the outline you create to completely match the shape of the masks, then probably the easiest way to do this is to apply the ‘stroke’ effect, which will place a line over your mask shape which matches the animation.
    Otherwise you could draw your line using the pen tool (which creates a mask) then apply the ‘stroke’ effect. To animate, hit ‘m’ in the timeline panel to bring up the mask properties, click on the stopwatch next to ‘mask shape’ then adjust the shape/add keyframes over time as you would normally.
    There may be an easier way, in which case I’m sure someone will be along soon to say!
    James
  • Scott Novasic
    July 28, 2009 at 7:13 am
    trapcode 3d stroke is a nice option with even more flexability than the generate stroke feature allows.
    If you have the plug in. It is a motion graphics “hall of fame” plug in…..
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Todd Kopriva
    July 29, 2009 at 12:03 am
    You can animate paths in a shape layer. You can also animate the drawing on or off of a path’s stroke with the
    Trim Paths path operation.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
