Activity Forums Adobe After Effects animating a mask?
  • animating a mask?
    Posted by Paul Nevison on December 12, 2007 at 8:52 am
    Hey
    I have created a mask around a person’s face and basically want to animate that mask as the person moves in the frame (rotoscope)
    how do i actually create keyframes for each of the points on the mask.
    so far i can only find how to keyframe the entire mask shape and not the individual points in the mask
    thanks
    Macpro Duel core 3Ghz
    4.0G RAM
    OS 10.4.10
    QT 7.2
    FCP 6.0.1
    AE CS3
    BMD Decklink HD Extreme 6.6
    PAL Land
    Paul Nevison replied 18 years, 8 months ago 4 Members · 4 Replies
  • Jason Milligan
    December 12, 2007 at 7:00 pm
    A quick additional note:
    It is often easier to animate multiple simple masks working together than one intricate mask.
    For example:
    If you were going to roto a torso and head, you may have separate masks for the body, the head, the forearm, hands, etc.
  • Frank Hardie
    December 13, 2007 at 12:40 am
    Keyframing the mask shape is the same as keyframing the individual points (vertices), because the shape is determined by the position of those points.
  • Frank Thomas
    December 13, 2007 at 12:49 am
    Deleted
  • Paul Nevison
    December 13, 2007 at 3:57 am
    thanks for the responses.
    I probably didnt explain myself that well, but i figured out what I wanted to do, which was to animate the individual vertices over time….found I could adjust those with the help of the command key.
    thanks again!
    good tip on using multiple masks as well
    4.0G RAM
    OS 10.4.10
    QT 7.2
    FCP 6.0.1
    AE CS3
    PAL Land
