Activity Forums Maxon Cinema 4D Animating a Light on a Spline
  • Animating a Light on a Spline
    Posted by Michael Gibson on September 28, 2009 at 7:26 pm
    I am having a problem with attaching headlights to a train that is animated on a Spline. The train group is using a Spline Wrap. The lights are in a null and when I drag them into the the train group nothing happens. I’ve parented them to a object in the train group and still nothing. If anyone has any ideas it would be appreciated. Thanks
    Simon Graham replied 9 years, 5 months ago 4 Members · 3 Replies
  • Brian Jones
    September 29, 2009 at 1:53 am
    I’m guessing that the spline wrap won’t affect nulls (or lights). You could attach the light null to the spline with an Align to Spline tag and just adjust the Wrap’s Offset and the ATS’s Position parameter.
  • Adam Trachtenberg
    September 29, 2009 at 3:01 am
    Easiest way to do it probably is to use a cloner. If your train object has some points where the lights should go, select them and create a point selection tag. Otherwise just create a couple disconnected points and put them where the lights should be (and do the selection tag thing).
    Then create a cloner, drop the light into it, set it to object mode, reference the geometry that has the selection tag, and restrict it to the tag.
  • Simon Graham
    March 13, 2017 at 12:08 pm
    You just saved my ass!
