Activity Forums Adobe After Effects animating a layer along an imported path over time
  • animating a layer along an imported path over time
    Posted by John Boy on March 14, 2006 at 5:03 pm
    Hi!
    I need to take a layer in after effects and make it move over time along a spiral vector i have created in illustrator. I know about auto orient along path but I don’t want to keyframe a spiral in position keyframes to create the motion path that way.
    Hope that makes sense! Thanks in advance, john
    Alon_a replied 20 years, 5 months ago 2 Members · 1 Reply
  • Alon_a
    March 14, 2006 at 8:09 pm
    You can copy the mask from Illustrator and paste it onto a solid in AE, which will create a mask. Then, copy the mask shape (emphasis: the *shape*, not the whole mask object) and paste it into the position parameter of the layer you want to animate. I’m not in front of Illustrator right now so I’m not sure if you can paste the path directly into the position parameter, but the two-step process should definitely work.
    (There’s a setting in Illustrator you need to take care of for the copy paste to work, I think it’s “preserve paths” and “copy as AICB”).
    AA
