Activity Forums Adobe After Effects Animating a knot AE
  • Animating a knot AE
    Posted by David Amichai on August 23, 2013 at 8:27 pm
    I’m trying to create an animation of a rope tying itself in AE.
    Basically im using two shape layers. One a solid stroke (parent), the other a dashed stroke (child). I’m animating splines to loop the rope around itself and create a knot.
    EXAMPLE
    AE knot
    Problem is since the dashed line is a single layer it intersects in such a way that it makes it very hard to clean up. Any ideas to make it look more like a knot and not a jumble
    FINAL
    Any help on this would be much appreciated.
    http://www.davidamichai.com
    Tudor “ted” jelescu replied 13 years ago 3 Members · 2 Replies
  • Mathew Fuller
    August 23, 2013 at 9:42 pm
    1.Make both your original strokes slightly thinner
    2.Duplicate your solid stroke, make it hard edged with a dark brown or black and place it under your other strokes.
    3. Change the original strokes to feathered edges and it should look like it has a shadow along the edges, giving it the illusion of depth, and will help separate it visually from all the other brown rope when it becomes a knot.
    _________
    Alternate idea… do a soft bevel on the alpha and maybe a little outer glow (dark color). You may have to precomp for this to look right.
    My Work:
    https://www.morecompletefx.com
  • Tudor “ted” jelescu
    August 25, 2013 at 5:39 pm
    Another way would be to do this 3D using Zaxwerks 3D Serpentine:
    https://zaxwerks.com/3dserpentine/
    Tudor “Ted” Jelescu
    Senior VFX Artist
