Activity Forums VEGAS Pro Animating a ‘jump’ motion?
  • Animating a ‘jump’ motion?
    Posted by Chris Crenshaw on August 16, 2009 at 8:17 am
    Hey everyone, Im pretty new to animations, and was wondering how you would go about keyframing a jumping motion. As I understand it, the frames transition from point A to point B in a straight line. Is there anyway to arc it?
    Theo Van laar replied 17 years, 1 month ago 4 Members · 3 Replies
  • Mike Kujbida
    August 16, 2009 at 10:03 am
    Despite repeated requests for Tension, Continuity and Bias controls like those found in Lightwave, all you can do is add more keyframes between points A & B to smooth out the jumping motion.
  • Peter Friend
    August 16, 2009 at 9:03 pm
    If you right-click a keyframe, there are a number of choices for how the values will move in/out of the keyframe value – it’s not full animation control, but a lot better than nothing.
  • Theo Van laar
    August 17, 2009 at 6:39 am
    There is a plugin for Vegas available which allows full control over the behavior of the transitions, including the ARC-shape (that results in the appearence and the disappearence of the second event: spicemaster
    Theo
