Activity Forums Adobe After Effects Animating a dotted line with varying distance between the dots.
  • Animating a dotted line with varying distance between the dots.
    Posted by Flogan Van uebel on July 23, 2016 at 3:45 pm
    Look at the movement curves of the ball in this guys tutorial:
    https://youtu.be/JlLcMa2fQ4U?t=2m51s
    What I want to do is to create a dotted line like that, where I have control over the distance between the dots, and their position along the path.
    I need the effect to show how an object changes it’s velocity along the Z-axis due to gravity.
    Thanks in advance 🙂
    Edit: I thought of a way to do it, but it involves creating 150 animated shapes… Any help with automating the process would still be greatly appreciated.
    Kalleheikki Kannisto replied 10 years ago 3 Members · 2 Replies
  • Greg Gesch
    July 24, 2016 at 1:32 am
    Hi. You could use text “full stops”/”periods” (.) along a path, then use the “tracking for selected characters” – the AV setting in the text’s character panel – to change the spacing between them.
  • Kalleheikki Kannisto
    July 24, 2016 at 7:59 am
    A particle system emitting one particle per frame should do it.
