Activity Forums Adobe After Effects Animating 3D objects in After Effects
  • Animating 3D objects in After Effects
    Posted by Anthony Miller on May 25, 2009 at 7:44 pm
    Hi All,
    Not sure how this works so an explanation would be most appreciated. Let’s say I import a 3d tank model into AE. Obviously, the tank is still and not animated (the treads of the tank do not move). Can I animate the treads somehow in After Effects so it appears the tank is moving? Can I rotate the turret or is all of that done only in a 3D program. Any advice is greatly appreciated.
    Many thanks in advance for your assistance.
    //Marshal
    Anthony Miller replied 17 years, 4 months ago 4 Members · 5 Replies
  • Gene Hoffman
    May 25, 2009 at 9:11 pm
    I read your post below. You need a 3D application for this and then composite that into AE. Do yourself a favor get some training, because if you need to ask a question like this there is a lot you need to learn before tackling a project like compositing a realistic 3d modal in a scene.
    Gene Hoffman
  • Anthony Miller
    May 25, 2009 at 10:42 pm
    Mr. Hoffman,
    Thank you for your response. Not only do I agree with your post but all that comes to mind is a resounding “of course!” as it pertains to training. Yes, I am new at this but also like to know where to gear my efforts which you have helped to answer.
    Thank you.
  • Israel Long
    May 26, 2009 at 3:29 am
    AE CS4 allows you to import Photoshop “3d” objects into AE with limited functionality.
    Once imported from Photoshop, you can tumble-around the object in 3d, animate 3d position & rotation, etc. using the null that is attached to the layer.
    However, you do not have the ability to cast shadows, use lights, and the higher-quality rendering may be slow on some machines.
    Also, if your object has multiple parts, such as a tank turret, you cannot control that separately unless you bring that in as a sepparate 3d object and place it on top of your tank body, and … well you get the idea.
    It can get needlessly complicated very quick.
    Here is a quick overview video of this process from Lynda.com I found using a quick google search:
    https://www.youtube.com/watch?v=sor1ac-cp2M
    Enjoy:)
    Israel “Izzy” Long
    ragecg.com
    MNAE User Group Co-Manager
    https://groups.adobe.com/groups/74dab16438/summary
  • Ken Green
    May 26, 2009 at 2:20 pm
    @ Gene Hoffman
    You need to chill out, Negative Nancy. This guy is asking a legitimate question. You don’t support the image that the Creative Cow community is a welcoming and helpful community.
    KennethGreen.net
    Redefining Fine Art to Fine Wine.
  • Anthony Miller
    May 26, 2009 at 4:02 pm
    Thank you for all the assistance, gents. I truly appreciate it.
    … and regarding Gene Hoffman, he took his baseball and went home.
    //Marshal
