Activity Forums Adobe After Effects animating 2d text along a wall toward the viewer
  • animating 2d text along a wall toward the viewer
    Posted by Russell Birkett on July 1, 2014 at 12:34 pm
    Hope someone can help.
    I have some text scrolling along a wall toward the viewer (the sort of thing you see at the stock exchange). That’s all working fine, but I’ve come up against a problem now as I’m trying to get it to bend around a corner. The corner is a gradual curve rather than an abrupt 90 degree bend. I’ve tried bending the layer but that just doesn’t look right. It’s live footage but the camera is stationary. Any advise would be appreciated.
    Russ
    Atiqur Sumon replied 12 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Stephen Smith
    July 1, 2014 at 2:42 pm
  • Russell Birkett
    July 1, 2014 at 7:02 pm
    Thanks for that Stephen. I did have a look at bending the layer, but I think that it only bends it from the middle ? (although I could be wrong there), where as what I require is mostly a straight side with a little bit of bend at the far end. Does that make sense?
  • Michael Szalapski
    July 1, 2014 at 8:43 pm
    Bezier Warp might do the trick for you. Or Mesh Warp.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Joseph W. bourke
    July 1, 2014 at 9:02 pm
    You might want to try this script – it would make it really easy:
    https://aescripts.com/3d-splitter/
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Russell Birkett
    July 2, 2014 at 9:11 am
    Thanks for these suggestions guys – I’ll have a look at them today
    Cheers
    Russ
  • Russell Birkett
    July 2, 2014 at 3:27 pm
    I think Bezier mesh is a winner. Not quite as intuitive as I thought AE would be, but it gets the job done.
    Many thanks again
    Russ
  • Atiqur Sumon
    July 7, 2014 at 9:36 am
    The simplest type of autostereogram consists of horizontally repeating patterns (often separate images) and is known as a wallpaper autostereogram. When viewed with proper convergence, the repeating patterns appear to float above or below the background. The well-known Magic Eye books feature another type of autostereogram called a random dot autostereogram. One such autostereogram is illustrated above right. In this type of autostereogram, every pixel in the image is computed from a pattern strip and a depth map. A hidden 3D scene emerges when the image is viewed with the correct convergence. Source : https://en.wikipedia.org/wiki/Autostereogram
