Activity Forums Adobe After Effects animated vector paint is jumpy when playback speed is reduced…
  • animated vector paint is jumpy when playback speed is reduced…
    Posted by David Lieberman on March 6, 2008 at 6:52 pm
    hello,
    i’ve got an animated vector paint effect. its quite fast so i had to slow it down, but when i slowed down the playback speed it becomes somewhat jumpy and not as smooth..
    i was wondering if theres some kind of effect i can put on top of it which will almost shadow its movement so to make it look smoother… if that makes any sense?
    thanks
    thanx for the help.
    Jens Enqvist replied 18 years, 6 months ago 2 Members · 3 Replies
  • David Lieberman
    March 6, 2008 at 7:28 pm
    sorry for not being clear. It isnt possible as far as i know to keyframe animated vector pain effect. You simply draw what you want, and the animation is created according to the speed and position of the mouse pointer…
    so first i drew the vector pain with the mouse, while its on ANIMATE STROKE. I then set it to REVEAL LAYER/path and then i tweaked it with the playback speed option in the vector pain effect pallette.
    does that clarify it a bit?
    thanx for the help.
  • David Lieberman
    March 6, 2008 at 10:24 pm
    fair play, but i’ve tried to do what i need to do with stroke and write-on, and it doesnt allow too many things. such as creating a write-on effect simultenously from two different points to build something like a flower for example.
    I know i can split the layer but i have a lot of art made only of strokes, but many of them, which arent connected..so selecting paths wouldnt work at all… im only left with vector paint or creatings masks that reveal the shapes..
    thanx for the help.
  • Jens Enqvist
    March 7, 2008 at 8:14 am
    Try CC WideTime, that has worked for me in a similar case.
