Activity Forums Adobe After Effects Animated titles – white type for FCP import
  • Animated titles – white type for FCP import
    Posted by Miklos Philips on September 20, 2005 at 5:47 pm
    I’m not sure if this is After Effects of FCP related… I’m animating some text in AFX and I’ve been noticing a weird thing. I create my titles with the text tool and convert to outlines to apply some effects (drop shadow, etc). When I render out I see sometimes a fine vertical line appear for a few frames here when teh text moves and there that appears to be the edge of the 720×480 frame (my setup for the comp) when I animate the titles moving from left to right let’s say. This happens with imported Illustrator outlines as well for titles. I had a work around in Illustrator for it but forget what it was. Anybody else experiencing this problem and have a solution for it? I’m exporting as “lossless+alpha” for import into FCP. Interestingly when I look at the QT file itself of just the render it looks clean.
    Point Zero Pictures
    <https://www.pointzeropictures.com>
    Roland R. kahlenberg replied 20 years, 11 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 21, 2005 at 2:24 am
    The artefact could be due to your display card. Your best bet is to bring the rendered movie into FCP and view the results on a broadcast monitor.
    Is there a reason why you are converting the text layer to outlines? Unless you want to manipulate the mask shapes to have more control over each character’s shape, there isn’t a rationale for it.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
