Activity Forums Apple Final Cut Pro Legacy Animated Titles
  • Mark Suszko
    September 4, 2013 at 1:48 pm
    The easiest way to do this is to use Apple Motion, where arrow type effects are easy to set up. Motion can create the arrowhead and paths, but the example looks like someone took a simple still graphic of an arrow, and animated the keyframes for a soft-edged wipe or crop effect, plus an overall fade effect.
    You can also make your “lower third” title bars this way: numerous pre-made templates are already in Motion. The title bar in your example looks like it was made using Motion and it’s included LiveType effects.
