Activity › Forums › Adobe After Effects › Animated Text Presets
  • Animated Text Presets
    Posted by Brian Redding on June 20, 2005 at 1:08 am
    Did a search and didn’t find the answer for this one.
    Using the “Straight In Multi-line 2” preset, the text enters from the right side. How do I get it to enter from the left? Forgive me if this is simple.
    Brian Redding replied 21 years, 3 months ago 2 Members · 2 Replies
  • Jim Zito
    June 20, 2005 at 1:27 am
    Hey Brian,
    After you apply the preset, go under the ANIMATOR 1, RANGE SELECTOR 1. and change the X POSITION value to a negative. If you scrub that setting (including the Y POSITION) you’ll see where the text will start from before animating on.
    Whenever you apply a text preset type UU and you’ll see all the parameters that that preset has changed. That usually gets you started if you want to vary the preset at all.
    Hope that helps,
    Jim
  • Brian Redding
    June 20, 2005 at 1:42 am
    Jim –
    Wow, talk about a quick response! Thanks for the info!
