Activity › Forums › Apple Final Cut Pro Legacy › animated stills go bad in dvd
  • animated stills go bad in dvd
    Posted by Russ Spencer on November 18, 2009 at 9:35 pm
    Just finished a film that includes a sequence of still photos, JPEGs, that have been animated. Look great on the timeline but when they are output as MPEG-2 and made into a DVD, they look terrible, all bit-mapped. How do I fix this?
    Stephen Smith replied 16 years, 10 months ago 2 Members · 3 Replies
  • Stephen Smith
    November 18, 2009 at 10:09 pm
    Are you using a broadcast monitor to see if the the photo animation looks how you want it? What settings did you use to make your mepg-2?
    Utah Video Productions
    Check out my Motion Tutorials
  • Russ Spencer
    November 18, 2009 at 10:12 pm
    I don’t have a broadcast monitor.
    For my MPEGs, I use one past CBR at 6.9
    Not all of the stills goes bad.
  • Stephen Smith
    November 18, 2009 at 10:20 pm
    If you can afford a Broadcast Monitor it is worth it. Things look different on a computer monitor, interlacing issues is a good example.
    For DVD compression I recommend a Two Pass VBR. It is possible for Compressor to struggle with compressing an image and not other…. However, I don’t think that is the problem.
    Is the bad images flickering when you watch it? Or are they turning into big squares?
