Activity Forums Adobe After Effects animated spray paint effect
  • animated spray paint effect
    Posted by Simon Robson on January 6, 2006 at 1:43 pm
    I’d like to achieve an animated spray paint stencil effect, as if paint is being sprayed in a stencil onto a wall. My knee jerk reaction would be to achieve this with an alpha matte and then the lair that is being matted would have animated masks revealing a solid at different opacities as if to mimic an aerosol. I’m not sure if this is the best way, and maybe there’s a nifty effect technique that would solve it better. Any ideas?
    Cheers,
    Simon
    Simon Robson replied 20 years, 8 months ago 2 Members · 2 Replies
  • Rob Kahn
    January 6, 2006 at 3:13 pm
    Create two solids. The bottom will be your stencil and final painted image, the top will be the spray paint. Create a mask the shape of our stencil. Duplicate the layer and change the mask mode to subtract. The subtract layer is your stencil and the add layer is your resulting painted image. You probably want to change the color of the stencil solid. On the third solid layer above use the Paint tool (set to the color of your painted image. In the paint panel set duration to write on use a feathered brush and cover your stencil with paint. In the Effects panel Check the paint on transparent box. Pre comp the paint and stencil layers. Pull back the stencil/paint comp to reveal the final image. (add a little paint drip with the paint tool).
    Hope that’s what you were looking for.
    Rob
  • Simon Robson
    January 6, 2006 at 3:41 pm
    thanks rob, I’ll give it a shot later
    Simon
