Activity Forums Adobe After Effects Animated pictures into the movie
  • Animated pictures into the movie
    Posted by Cuel on May 14, 2005 at 6:11 pm
    Hi, I’ve just learned how to remove the white around my picture in photoshop and then import it to AE 6.5 It was pretty simple but when I tried with .gif’s I didnt really get the same effect. If the animates is now white around it doesn’t play. I don’t really know how to fix this.
    The closest I got to where i wanted was when i chose one and one layer after each other and edited hte length of them. Didnt really work as i wanted then either. How can put all the layers into one movie in the composiotn and move it around? Help appricated. you might come into the spec thanks to =)
    Cuel replied 21 years, 4 months ago 1,150 Members · 1 Reply
  • Cuel
    May 15, 2005 at 1:07 pm
    bump.. Maybe you guys didn’t understand. I do not know how to import .gifs (animated pictures, frames after each other) into my movie. Or I do know how to do it, it is just that it gets black around it and when i try to import .psd instead, I can only choose one and one layer after each other.
