Activity Forums Boris FX Animated painting “path” on a map
  • Animated painting “path” on a map
    Posted by Carlos Silva on August 1, 2012 at 10:35 pm
    I am trying to create a simple animation based on the Red5 paint tool. I have created a “paint layer” and then drawn on the canvas, which is a map. Actually, I would like to create an animated painting “path” on the map, showing along time the painting being drawing, but I am unable to do this. All paints I could create are static and doesn’t have keyframes (I made a draw, not an animation!).
    I would appreciate help to:
    a) How could I create such animation?
    b) Is it possible to add a “drop shadow” to the animated painting “path”?
    Thanks in advance,
    Cadu
    Carlos Silva replied 14 years, 1 month ago 3 Members · 4 Replies
  • Peter Mcauley
    August 2, 2012 at 2:58 pm
    Hi Carlos,
    Animating a paint stroke is fairly easy – here’s how to do it:
    • To make a dash or dot that follows the paint path:
    • Set the time marker (CTI) to the start of the timeline
    • Create the stroke
    • Make the Paint track / layer the current selection – you should see two tabs in the control window Paint Tab and Transform Tab
    • In the paint tab, set the Strokes End to a very small value – start with a value of 2
    • Set the animation type to Linear
    • Set the Stroke Begin to 0
    • Move to the end of the timeline
    • Set the Strokes Begin to 98
    • Set the Strokes End to 100
    • Now as you playback the timeline, you should see the stroke moving per your animation
    • If you want to create a continuous line paint-on and do not want to see a dash or dot (which is what I have described above) then only make adjustments to the Stroke End parameter and leave the Stroke Begin parameter set to 0 with no animation.
    To make the drop shadow, move the paint track onto the face of standard shape track, then turn off the eyeball on the media sub-track. You can then enable the drop shadow option for that track.
    Feel free to send me your email address and I’ll send you a RED 5 project that shows you how to do this. You can contact me at peterm@borisfx.com.
    I hope this helps,
    Peter.
  • Marcus Warren
    August 2, 2012 at 3:36 pm
    Peter, it would be great if mini-tutorials, like the one you supplied for this post, could be collected somewhere. You churn out a few number of these on this forum, so it would be cool to have easy access to them, whether here or on the Boris FX site.
  • Peter Mcauley
    August 2, 2012 at 3:40 pm
    Hi Marcus,
    You are right and actually I am in total support of this. We’ve done some of this in the past and to help that cause, I’ll record a mini tutorial of this paint feature and post it for everyone.
    Thanks for mentioning this.
    Peter,
  • Carlos Silva
    August 2, 2012 at 6:17 pm
    Hi Peter,
    Many thanks for explanation!
    As suggested, it would be great to find tutorials on Boris joined in some place. To newbies – as me – it would be handy!
    Cheers,
    Carlos
