Activity Forums Adobe After Effects Animated outline/stroke
  • Animated outline/stroke
    Posted by Michael Brookes on November 22, 2009 at 11:05 pm
    Hi
    I am trying to create an animation with multiple layers, with each underlying layer having a thicker stroke around the outline of the animation. I want these outlines to be very very thick, and ideally expand so that they reach the edge of the screen, in a looping animation style.
    The way I have gone about this is to apply a matte choker to the layers, and scale the choke/iterations until I have the sort of outline I want.
    However, this is massively render intensive and just getting it to process to view in AE takes about a minute. To render it would take about a week!
    Is there a better way of doing this? It doesn’t seem such a complicated effect to do.
    many thanks
    michael
    Raymond Tuquero replied 16 years, 9 months ago 2 Members · 1 Reply
  • Raymond Tuquero
    November 23, 2009 at 6:36 am
    Have you tried creating lines with you pen tool and then generating a stroke?
    Also … I would recommend previewing you animation in a low res format to make sure it is moving the way you want. Then when you are happy and ready to export … there a few tips to help with the export render time.
    My Fav tip … Hit Caps Lock ON and purge your memory … I have noticed between 1% – 5% increase in Render times and less waiting for the render … hey 1-5% can be a big number when your talking about hours of rendering.
    Good Luck.
    -Raymond Tuquero-
    Houston Based Freelancer
    http://www.rtuqvidere.com
