Activity Forums Maxon Cinema 4D Animated object moves when added to a parent null
  • Animated object moves when added to a parent null
    Posted by David Biederbeck on January 22, 2013 at 7:30 pm
    Is there any way around the fact the adding a animated object to a parent null is moving former locations of the animated object.
    I’m have a character, and want him to rotate around an object once he flies to its location.
    Adam Trachtenberg replied 13 years, 7 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    January 23, 2013 at 3:53 am
    Set the parent null’s location to 0,0,0.
  • David Biederbeck
    January 23, 2013 at 4:00 am
    Found a work-around and am in a net render currently.
    I understand this, but the object I would like to rotate around is not at 000.
    For instance I can link and unlink an object in After Effects and it doesn’t affect previous movement, no matter where the null is.
    I’m wondering if there is a work around.
  • Adam Trachtenberg
    January 23, 2013 at 5:24 pm
    I would recommend a constraint tag (in the character tags) with a parent constraint. You can parent your object to a null with offset — so it doesn’t jump.
