Activity Forums Adobe After Effects Animated OBJ disappears by adding a texture map?!
  • Animated OBJ disappears by adding a texture map?!
    Posted by Chantal Gfeller on October 14, 2016 at 12:33 pm
    Hey Guys! ?
    I’m facing an issue that drives me crazy.
    I animated in AE CS6 a scene with Element 3D 1.6.0 where cupcakes fly and swirl around.
    I added the diffuse texture in a later step. Everything is working out except some separate cakes, I animated in a different way.
    Usually I animated the group but for 2-3 cakes I chose to animate their position and rotation with “world-transform”. They are following a motion path and whenever I add the diffuse texture map, they disappear in my comp! I checked if it has something to do with the opacity but it doesn’t.
    Does anybody of you have an idea what the problem could be?
    Thanks a lot in advance!
    Cheerio
    Chantal Gfeller replied 9 years, 10 months ago 1 Member · 2 Replies
  • Chantal Gfeller
    October 14, 2016 at 2:50 pm
    E D I T :
    I just realised it’s because of a light in the comp that I used as an emitter for bubbly particles to follow the cake.
    Still not sure how to fix it… Gonna try and keep my post updated!
  • Chantal Gfeller
    October 14, 2016 at 2:54 pm
    pre-comps is the key… oh hell is this awkward!
