Activity Forums Adobe Encore DVD Animated menu stop if I add a button.
  • Animated menu stop if I add a button.
    Posted by Prezak Prezakios on May 17, 2009 at 8:23 pm
    Hi everyone,
    It is the second project that I have created in Encore DVD. In the first one, I had add a menu which had been binded with a video and a song. In this menu I had add ,successfully, some buttons. The video played normally and the buttons was linked with chapters. Now, I have created a second project,similar to the first one, which contains a menu binded with a video,as the first project. The problem is that when I put a button in the menu then the video,which is binded to the menu, stops playing…and it appears only the first frame of the video frozen.
    Can anyone explain me which is the problem this time?
    P.S.: ” I opened the old project and tried to change the video in the menu and it stopped playing again. The same is happening when ,in the old project, I try to put extra buttons in the menu…it stops be animated menu.”
    Thank you in advance.
    Joe Bowden replied 17 years, 3 months ago 3 Members · 2 Replies
