Activity Forums Adobe After Effects Animated Mask
  • Animated Mask
    Posted by Alen Smajic on November 17, 2008 at 3:54 pm
    I am looking for the easiest way to animate a hand that’s drawing an image. The file is split up into three layers, pavement, drawing, and hand. Should I use masks and how could I attach the movement of the hand to the mask?
    Please let me know if you need further clarification on what I’m trying to do.
    Alen Smajic replied 17 years, 9 months ago 2 Members · 2 Replies
  • Craig Hellen
    November 17, 2008 at 4:41 pm
    if i was doing this i would…
    use the write on tool to reveal the image as it was being drawn ( though you may need to split up the paint layer a bit more and do it in seqence)
    Make one comp for each part of the drawing (ie outer triangle, inner triangle etc) on each put the hand layer on the comp as well ensuring that the anchor point is at the tip of the brush. (paste the hand layer from the 1st comp onto the different ones to make sure the anchor point remains in the same place)
    Twirl down the expressions for position on the hand and pickwhip to the write-on position
    assemble all the comps together in a final comp adding additional animated “hands” where needed to join all the comps up….
    DONE
    Dunno if this is the best way to do it but its how i would start out.
    Hope this helps
    Co-Director Podchains Ltd
    Video Producer / Motion graphics designer https://bexmedia.net
  • Alen Smajic
    November 17, 2008 at 4:53 pm
    Craig,
    Thank you for your time. I will try this.
