Is your mask on a solid layer? Did you duplicate the mask or the solid, because you need to duplicate the solid(layer) and create two different solid colors. It would be a lot more difficult to duplicate a mask on a single layer and have the fills be 2 different colors—though it probably could be done.
So if you are talking about a duplicated solid layer just press “shift+cntl+y” to access the solid settings and you can change the color. There is a check box in the corner that says “Affect all layers that use this solid”, make sure that isn’t checked or you will change the color of your original solid also.
Johnny Cuevas, Editor
Thinkck.com
“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb.
