Activity › Forums › Zaxwerks › animated lines on a spinning globe
  • animated lines on a spinning globe
    Posted by Ernie Geefay on February 21, 2006 at 8:53 pm
    I want to trace my travels around the globe with an animated line traveling across the globe, from continent to continent.
    I have a jpeg map of the world that wraps nicely around the globe in Invigorator but I can’t figure out a way to animate the line going around the globe.
    Anyone have a good idea?
    Ernie Geefay replied 20 years, 7 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    February 22, 2006 at 1:19 am
    Hi egeefay,
    Sure. Layer Mapping is the key to one way of doing it.
    Make a comp the same size as your globe map. Add the globe map to it. Now, add another image of the entire path with a transparent background on top of the globe map. Use an animated mask to reveal the path as you go along in time.
    Apply the Layer Map to the sphere and you should be good to go.
    If you have issues with this, please let us know.
    Jon
  • Ernie Geefay
    February 22, 2006 at 1:54 am
    Hi
    Thanks. Layer mapping! It worked like a charm!!
    Ernie
