animated graphics On the air with their transparency
Hi there,
Im in my second year at school in broadcast television and i need a work around to get accuratly my animated graphics On the air with their transparency. The problem is that we dont have the newest Deko.
So far, I create these animated lower third with After effects, transfer that on SP, playback on a VTR and “Key” by linear. This was done Upstream in M/E, and I then add over in dowstream the; name, title … , with the CG Deko 500.
But “Keyed linear” those animation is a bit restrictive, some of the graphics contains levels of blacks wich are “clip” in the procedure.
Is there a better way to work with linear or even by using Key fill/Key source. I though render my alpha channel separetly in AE, transfert those two on separate SP, Sync/lock both TC VTR, then assign the graphics and is Alpha to Key fill/source of the Switcher. But, this is a bit! … tricky, and I dont even know if it will work.
So advice on how I should go on will be appreciate. thanks!equipement:
Deko 500
GVG 200
3 BCB60, 3 BCB70, 1 BCB75
