Activity Forums Maxon Cinema 4D Animated gradient alpha revealing lines…
  • Animated gradient alpha revealing lines…
    Posted by Joey Morelli on November 2, 2007 at 12:54 pm
    Hello,
    I know…sounds a bit confusing. I don’t know how to explain it well so here goes.
    I am trying to reverse engineer a spot element. It is a group of stacked 3D lines (5) in sort of a wavy spline shape that reveal on & off with an animated alpha gradient. I have been able to recreate perfectly the lines in 3D Stroke (using the Offset parameter to animate the lines across a wavy spline) and C4D but can’t for the life of me figure out how that softness is created on the start & end.
    Here are the frames containing the lines I am speaking of.
    https://www.marasmalley.com/images/Americas.Cup.jpg
    Here’s the spot the lines appear in (10 mb):
    https://www.digidojo.net/pics/tech_pics/animated_lines.mov
    These lines wipe across the screen with a wide long gradiated transparency on each end. I can create these lines in AE & C4D but can’t figure out how to do the transparency (it almost looks like a 3D track matte). Any help would be greatly appreciated.
    Thank you so much 🙂
    Joey
    Adam Trachtenberg replied 18 years, 10 months ago 2 Members · 5 Replies
  • Adam Trachtenberg
    November 2, 2007 at 4:28 pm
    I would use a layer shader in your alpha channel and multiply a gradient over your lines.
  • Joey Morelli
    November 2, 2007 at 4:57 pm
    Thanks for replying Adam. Can you expand on that please?? Modeling is not a problem for me but shaders are not my strong suit.
    Thank you so much
    Joe
  • Adam Trachtenberg
    November 2, 2007 at 6:15 pm
    It would probably be easier to look at an example.
  • Joey Morelli
    November 2, 2007 at 6:41 pm
    Awesome, Adam…thank you for posting that. One more thing…how is the actual wipe animated keeping both edges soft throughout?
    Thank you for your help.
  • Adam Trachtenberg
    November 2, 2007 at 9:07 pm
    Ahh … wellll … hmmm … that’s going to be a little tricky! Guess I shoulda anticipated that one. 🙂
    One way you could do it would be to use Xpresso to use the sweep start/end parameters to drive the position of the gradient points, but that’s going to be pretty involved.
    And easier way would be to use a texture in place of the layer shader in the alpha channel, and instead of actually animating the sweep, animate the texture tag’s Y offset position. The downside is that you’re not going to get a fade as the lines disappear completely. You can either hide that with spline/object placement, or you can add the effect in post with a little rotoscoping.
    project file
