Activity Forums Adobe After Effects Animated GIF render problem
  • Animated GIF render problem
    Posted by Derek Hader on September 28, 2006 at 10:53 pm
    Hey,
    I have a:
    278×208
    Square Pixels
    15f/sec
    Full Res
    8 Second composition in AE 7.0
    Only 3 layers, one being my signature that appears using the Stroke effect.
    When I export as an Animated Gif, the resulting animation has a lot of red and blue noise dots over the majority of the image. I’ve tried a bunch of different frame rates, and output settings and cannot get rid of them.
    It exports fine as an AVI… y can’t i get a clean GIF??
    Thanks in advance,
    Skeets
    Derek Hader replied 19 years, 11 months ago 3 Members · 3 Replies
  • Wes Plate
    September 28, 2006 at 11:24 pm
    I don’t know, but here’s how I make my Animated GIFs:
    Render a Lossless movie out of AE
    Open movie in ImageReady (part of Photoshop install)
    Create Animated GIF from ImageReady
    — Wes Plate
    Automatic Duck
  • Roland R. kahlenberg
    September 29, 2006 at 10:21 am
    [Skeeter] “When I export as an Animated Gif, the resulting animation has a lot of red and blue noise dots over the majority of the image.”
    The artefacting sounds like it’s the result dithering. Try to reduce the number of colors in your image. GIF’s contain 256 colors – total. Stay away from wide gradients. See if this does the trick. Wes’ suggestion should work provided ImageReady does a better job in reducing the colors/optimizng the palette for the GIF animation – chances are that it does.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Derek Hader
    September 29, 2006 at 5:19 pm
    Thanks guys,
    Image ready seems to have solved the problem!
    -Later
