Activity Forums Adobe After Effects animated dots texture (array)
  • animated dots texture (array)
    Posted by Steve Gerges on February 8, 2012 at 2:11 pm
    hi i need to animate something looking similar to the attached image as a background for an animation, but i can’t figure out how to do it and would love to have some inputs about it…. actually i was trying to use particular’s grid emitter and a spherical field…so far it works ok, but as you can see from the image the circles need to be big in the center and thin out to the edges, and i really don’t know how i could achieve that effect with particular….. any ideas !??
    Steve – Art Director – http://www.remedia.lu
    Mato Kokotic replied 14 years, 7 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    February 8, 2012 at 2:28 pm
    This looks like it could be done using Plexus. If you leave the particles at dots only and do not activate the lines, and then apply a Spherical Field distortion (from the Plexus Tool Kit), then you need to position a camera on top, looking straight on at your particles. Those on the Spherical Distortion Field will appear bigger being close to the camera in 3d space. You may have to play with the angle of the lens (make it wider).
    https://aescripts.com/plexus/
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Steve Gerges
    February 8, 2012 at 2:31 pm
    this sounds not to bad… i’ll give it a try ….. the thing is i’m working with plexus ALOT for this animation and didn’t even thought about it….. i think it’s the thing about not seeing the forest because all of the trees 😉
    thanks.
  • Mato Kokotic
    February 9, 2012 at 2:41 pm
    What about Effects>Distort>Bulge?
    Or Spherify in Photoshop?
