Activity Forums Adobe After Effects Animated Cursive Writing
  • Animated Cursive Writing
    Posted by Kevin Muse on August 11, 2009 at 10:07 pm
    With CS4, whether you use AE or not, is there an easy way to do an animated signature or sentence using a Wacom tablet? (without redrawing with masks, etc? I tried a Flash program that would write in cursive for web, but the exported resolution for video just wouldn’t cut it. Any plugins, etc. available?
    Kevin Muse replied 17 years, 1 month ago 3 Members · 3 Replies
  • Todd Kopriva
    August 11, 2009 at 10:23 pm
    How about the Write-on effect?
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Filip Vandueren
    August 11, 2009 at 11:22 pm
    Check out the Motion Sketch palette.
    I’d create a Null, and use motion sketch to move it around with the wacom.
    The resulting keyframes for the Null’s position can be copy-pasted to the write-on’s effect position, if you first select the property in the timeline, and then paste.
    If you just paste those keyframes on a Solid with the effect, the solid will just move, so be sure to select the “Brush Position” property first.
    Alternatively, you could pick-whip an expression so the Brush position automatically get’s it’s value from the null.
  • Kevin Muse
    August 12, 2009 at 3:09 am
    I’ll try that. Thanks! The writeon requires redrawing.
