Activity Forums Adobe After Effects Animated circle entering stage
  • Animated circle entering stage
    Posted by Matthew Angus on October 4, 2012 at 5:35 am
    Hi guys
    Was wondering if anyone might know how to animate a circle (or dot) entering a stage (from left), then once it reaches a point, rotates on itself (similar to a page turn effect) then travels back but stops at halfway back.
    I have been trying plenty of techniques but cant seem to get it right, mainly around have the circle use a cylinder type effect as it turns on itself. This or some type of warp effect gives it a realistic feel as it turns on itself.
    Circle turn
    Above is a crude attempt, using just the y rotation to peform the turn. As you can see, it doesn’t really give an organic type of motion that I am after.
    Thanks for any help, if forthcoming, much appreciated.
    Matt
    Matthew Angus replied 13 years, 10 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    October 4, 2012 at 6:27 am
    Make the disk layer a 3d layer.
    Create a 3d Null.
    Offset the Null on the z axis and parent the disk to it.
    Animate the Null to move the disk and to turn. Because of the offset you will get a turn that is circular (the radius of the turn will be as big as the offset on the z axis).
    Turn Motion Blur on and apply Easy Ease on the key frames at the beginning and the end of the turn, both on the position and rotation.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • John Cuevas
    October 4, 2012 at 12:13 pm
    I messed around using CC Page Turn and came up with this: 4759_pageturn.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Matthew Angus
    October 8, 2012 at 10:15 am
    Thanks Guys
    I ended up working on the page turn effect and tailored it to get the effect that I was after.
    That and combined with a bit of motion blur ended up making it look realistic.
    Cheers
