Activity Forums Adobe After Effects Animate without Keyframes
  • Animate without Keyframes
    Posted by Roy Metni on June 4, 2017 at 10:51 am
    usually i animate an object without keyframes using this expression :
    ease(time,inPoint+0,inPoint+1,[0],[value]);
    how to apply the effect of the expression below to the above
    amp = .1;
    freq = 1.0;
    decay = 4.0;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n–;
    if (n == 0){ t = 0;
    }else{
    t = time – key(n).time;
    if (n > 0){
    v = velocityAtTime(key(n).time – thisComp.frameDuration/10);
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{value}
    Vadim Chernous replied 8 years, 4 months ago 3 Members · 2 Replies
  • Michael Szalapski
    June 7, 2017 at 9:40 pm
    The second expression requires keyframes.
    You cannot use the two of them together.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Vadim Chernous
    May 17, 2018 at 5:56 pm
    Animation without keyframes
    ________________________________
    1) Create Null with name = “Control”;
    2) Create two sliders control: 1 – “Start Number”, 2 – “End Number”;
    3) Create text layer and paste expression;
    4) Create one marker on your text layer;
    That’s all, Cheers ☺
    _________________________________
    startCount = thisComp.layer(“Control”).effect(“Start Number”)(“Slider”);
    endCount = thisComp.layer(“Control”).effect(“End Number”)(“Slider”)*1000;
    var num = Math.round(linear(time,inPoint,marker.key(1).time,startCount,endCount))
    num = Comma(num);
    [num]
    function Comma(number)
    number = ” + Math.round(number);
    if (number.length > 3)
    var mod = number.length % 3;
    var output = (mod > 0 ? (number.substring(0,mod)) : ”);
    for (i=0 ; i < Math.floor(number.length / 3); i++)
    if ((mod == 0) && (i == 0))
    output += number.substring(mod+ 3 * i, mod + 3 * i + 3);
    else
    output+= ‘,’ + number.substring(mod + 3 * i, mod + 3 * i + 3);
    return (output);
    else return number;
