Activity Forums Adobe After Effects animate within a mask
  • animate within a mask
    Posted by Daniel Schultz on November 23, 2013 at 5:19 pm
    This seems like it should be straight-forward, but can’t seem to find an answer for this.
    I have a simple rectangle mask that has a still image in it. I’m animating the mask around the screen, but I also want to change the position and scale of the image WITHIN the mask.
    Can’t seem to find the controls for that or info when googling.
    Anyone have an idea?
    Thanks much,
    Dennis Fries replied 12 years, 9 months ago 4 Members · 4 Replies
  • George Goodman
    November 23, 2013 at 5:43 pm
    Just animate the the image properties as normal.
    If you’re not getting the results you want, then you need to redo your mask. I don’t know what you’re trying to achieve, but maybe try taking it a step at a time. Go to a frame, scale the image and place it, then animate the mask path where you want it. Go to the next frame and repeat.
    Hope that helps,
    George
  • Todd Kopriva
    November 23, 2013 at 6:22 pm
    Don’t apply the mask directly to the layer; apply it to a track matte layer so that you can manipulate the mask and the underlying layer separately.
    https://helpx.adobe.com/after-effects/using/alpha-channels-masks-mattes.html#track_mattes_and_traveling_mattes
    After Effects team blog
  • Daniel Schultz
    November 24, 2013 at 2:17 am
    Thanks, Todd.
    That did the trick!
  • Dennis Fries
    November 30, 2013 at 9:21 pm
    When in doubt, precomp!
