Activity Forums Maxon Cinema 4D animate texture?
  • animate texture?
    Posted by Thomas Ernst on May 15, 2008 at 8:43 pm
    Hi
    this is probably really simple but I can’t figure it out: I have a reflective material that I’ve enhanced using an image in the environment channel. I’d like to animate the image across the face of the object to give the reflection a bit of life while the object is static. What’s the best way to do this?
    thanks
    –tom
    Thomas Ernst replied 18 years, 4 months ago 3 Members · 4 Replies
  • Adam Trachtenberg
    May 16, 2008 at 4:55 am
    AFAIK there’s no way to animate an environment map short of using animated footage. What you can do, though, is map your enviro map to a sphere surrounding your scene, give the sphere a compositing tag with “seen by camera” unchecked. Then set the tag’s exclusion tab to “include” and drag in the object that you want to receive the reflection. Finally, animate the rotation of the surrounding sphere.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Scott Thomas
    May 17, 2008 at 12:10 am
    I create a null that I parent everything in the scene to, including the camera and the lights. Rotate and keyframe the null and the environment will change.
  • Adam Trachtenberg
    May 17, 2008 at 12:35 am
    [Scott Thomas] “I create a null that I parent everything in the scene to, including the camera and the lights. Rotate and keyframe the null and the environment will change.”
    Aha! I forgot that trick!
    AdamT
  • Thomas Ernst
    May 17, 2008 at 2:16 pm
    thanks Scott, thanks Adam.
