Thanks Brian. It’s a second material added to the item just as a displacement channel to give moving detail to the surface with its transparency set to 100%. So no way to animate the rotation?
Also did you see my recent post about texture mapping? I obviously don’t understand the texture tag. I was trying to duplicate a material where the colour channel’s bit map had a slight change made to it by photoshop. When I reimported the modified bitmap (same parameters) and applied it to the duplicated texture tag, the mapping changed. -Any ideas?
Thanks again
XdcamEx & HD, C300, DSLRs, all sorts of production & post gear and a very untidy desk. On the East Coast of the UK
