Activity Forums Adobe After Effects Expressions Animate text on per letter using a custom flicker expression
  • Animate text on per letter using a custom flicker expression
    Posted by Tom Holmes on July 10, 2017 at 6:34 am
    I have the following expression which animates a layers opacity on in a flickering fashion:
    if (time < inPoint || time > outPoint){
    f = 0;
    }else if (time < (inPoint+outPoint)/2){
    f = timeToFrames(time – inPoint);
    }else{
    f = timeToFrames(outPoint – time);
    switch(f){
    case 0:
    case 2:
    case 4:
    case 6:
    0;
    break;
    case 1:
    25;
    break;
    case 3:
    50;
    break;
    case 5:
    75;
    break;
    case 7:
    100;
    break;
    default:
    100;
    break;
    Is there a way I can adapt and use this with a text layer’s animate and expression selector so the letters animate on separately (either randomly or in sequence) with this same animation.
    Thank you! ☺
    Tom
    Tom Holmes replied 9 years, 1 month ago 2 Members · 4 Replies
  • Dan Ebberts
    July 10, 2017 at 3:51 pm
    Add an Opacity Animator, set its value to 0, and an Expression Selector and use this for Amount:
    totalDur = 1.0;
    myStart = inPoint + (textIndex-1)*totalDur/textTotal
    myEnd = outPoint - (textIndex-1)*totalDur/textTotal;
    if (time < myStart || time > myEnd){
    f = 0;
    }else if (time < (myStart+myEnd)/2){
    f = timeToFrames(time - myStart);
    }else{
    f = timeToFrames(myEnd - time);
    switch(f){
    case 0:
    case 2:
    case 4:
    case 6:
    100;
    break;
    case 1:
    75;
    break;
    case 3:
    50;
    break;
    case 5:
    25;
    break;
    case 7:
    0;
    break;
    default:
    0;
    break;
    Dan
  • Tom Holmes
    July 10, 2017 at 5:14 pm
    Thank you so much Dan! You’re such a huge help.
    How could make the letters appear in a random order instead of in sequence?
    Tom
  • Dan Ebberts
    July 10, 2017 at 8:09 pm
    Like this maybe:
    totalDur = 1.0;
    seedRandom(textIndex,true);
    myStart = inPoint + random(totalDur - framesToTime(8));
    myEnd = outPoint - random(framesToTime(8),totalDur);
    f = 0;
    }else{
    switch(f){
    case 0:
    case 2:
    case 4:
    case 6:
    100;
    break;
    case 1:
    75;
    break;
    case 3:
    50;
    break;
    case 5:
    25;
    break;
    case 7:
    0;
    break;
    default:
    0;
    break;
    Dan
  • Tom Holmes
    July 10, 2017 at 8:24 pm
    Perfect, you’ve done it again.
    Thank you so much!
    Tom
