Activity Forums Maxon Cinema 4D Animate spline reveal
  • Animate spline reveal
    Posted by Dan Fredley on August 27, 2010 at 6:47 pm
    This is probably easy, but I haven’t been able to find any info: I have a spline with extrude nurbs placed in 3d space. I would like to make it reveal from left to right. The problem is I can’t just use a mask to reveal it in After Effects because it folds back and forth over itself like a ribbon. Is there an easy way to do this?
    Dan Fredley
    Dan Fredley replied 16 years ago 3 Members · 3 Replies
  • Jake Nelson-dooley
    August 27, 2010 at 7:04 pm
    I’ve had success with using a material with an alpha channel. You can set the alpha channel to gradient and then keyframe that. The Cow Team may have a better method.
  • Bruce Rudolph
    August 27, 2010 at 8:02 pm
    If you can achieve the same look using a sweep nurbs instead of extrude, you can animate the start and end growth values to create a reveal look.
  • Dan Fredley
    August 27, 2010 at 9:18 pm
    The alpha channel worked great. Now the client wants to give the spline a 3D look–right now it’s only 2D with the spline and extrude nurbs. Is there an easy way to add a slight z-dimension to it?
    Dan Fredley
