Activity › Forums › Adobe After Effects › animate seasonal snowfall on map
  • animate seasonal snowfall on map
    Posted by Joe LeMonnier on July 29, 2024 at 2:11 pm
    I am working on a map and need to animate the seasonal advance of the mountain snowpack as it starts on the peaks in November and moves to the valleys in December. I have a good Digital Elevation Model (DEM) of the area. Can you advise? Thanks in advance.
    Joe LeMonnier replied 2 years, 1 month ago 3 Members · 4 Replies
  • Michael Szalapski
    July 29, 2024 at 2:57 pm
    You can use the map with height information as a track matte for the snow layer. Animate, say, a Threshold effect (with some blurring and maybe Fractal Noise overlaid) to reveal the snow.
  • Joe LeMonnier
    July 30, 2024 at 2:39 pm
    I’d like to try that as it seems a better idea than what I’m using now Can you walk me through your method with more step-by-step?
  • John Cuevas
    August 1, 2024 at 3:22 pm
    Joe, if you are still working on this, could you upload the map to help give everyone a better idea of what we are working with?
  • Joe LeMonnier
    August 1, 2024 at 5:01 pm
    Using the DEM I’ve tried two methods
    1) I made stills of the levels of elevation, colored them white and animated them on the timeline, fading/blending in progression.
    2) I imported the DEM, set mode to lighten, went to Effects>color correction.levels and animated levels (especially gamma). This worked but was tricky and left color edges .
    Is there a simpler way to do the second method?
