Activity Forums Adobe After Effects Expressions Animate PosterizeTime
  • Animate PosterizeTime
    Posted by Eric Barker on June 23, 2009 at 7:17 pm
    Hello, I want to have a picture change every few frames, but have the duration speed up over time. I’ve created a picture sequence with 51 frams, and am animating the Time Remap property.
    I’m trying to use PosterizeTime() to determine the diration. If I simply plug a number in there, it works fine, but if I try to animate it using a variable, it doesn’t seem to work at all.
    frameRate=thisComp.layer("Null 1").effect("Slider Control")("Slider");
    posterizeTime(frameRate);
    var picts = 51;
    seedRandom (index, false);
    r=random();
    (picts/30)*r;
    Television Producer
    KTVF-11 Fairbanks, Alaska
    video.ericbarker.com
    Eric Barker replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
