Activity Forums Adobe After Effects Animate position in isometric 2D space
  • Animate position in isometric 2D space
    Posted by Chris Vo on August 20, 2015 at 9:08 pm
    Hi All,
    I have an isometric project that will require a lot of position animation — is there a technique to quickly and accurately animate my position movements along my isometric grid? For example when you hold shift, it constrains your movement linear x and y — can you do something similar along 30degrees/150degrees (any degree).
    Currently I’ve overlaid my isometric grid in my comp and eyeballing it but I’m curious if there’s a more precise/systematic way of doing it.
    Chris Vo replied 11 years ago 3 Members · 4 Replies
  • Kalleheikki Kannisto
    August 21, 2015 at 7:56 am
    Here’s how you could do it for 30 degree isometric:
    Make a precomp that is a square, about 1.5 times the longer dimension of your final comp. Put your isometric elements inside the precomp and scale each of your original elements to 173,2% (square root of 3 times 100%) on the y axis, then rotate them 45%.
    In your main comp, add two separate Transform effects to your precomp, the first one to rotate the comp -45 degrees, the second one to scale the height to 57,7% (1 divided by square root of 3 times 100%).
    Now you can drag anything inside the precomp x and y axis and it will become the 30/150 degree isometric axis in main comp.
  • Walter Soyka
    August 21, 2015 at 10:57 am
    Position a 2D layer which you’d like to move over the isometric grid in the center of your origin tile.
    Add a Point Control effect to the layer and name it “Grid Position”.
    Add a Slider Control effect and name it “Tile Width”. Measure the width of your isometric tile in pixels and adjust this slider accordingly.
    Add a Slider Control effect and name it “Tile Height”. Measure the height of your isometric tile in pixels and adjust this slider accordingly.
    Alt+click the position stopwatch and enter the following expression:
    xGrid = effect("Grid Position")("Point")[0];
    yGrid = effect("Grid Position")("Point")[1];
    x = (xGrid - yGrid) * effect("Tile Width")("Slider")/2;
    y = (xGrid + yGrid) * effect("Tile Height")("Slider")/2;
    value + [x,y]
    You can now use the Grid Position effect to address the screen in tile units.
    August 21, 2015 at 12:58 pm
    @Walter: Nice!
  • Chris Vo
    August 21, 2015 at 3:27 pm
    Thank you both for your responses. I went with Walter’s method because I’m importing iso graphics from Illustrator, therefore Kalle’s method would distort my original artwork (I presume).
    Clever method, Walter, it’s working like a charm!
