Activity Forums Adobe After Effects Expressions Animate position according to layer marker name
  • Animate position according to layer marker name
    Posted by Eva Lepik on May 1, 2017 at 12:38 pm
    Hey,
    I would need a bit of help with an expression.
    What I’m trying to do:
    When a layer marker’s name is “UP”, the layer’s y position should animate up by comp height
    and when a layer marker’s name is “DOWN”, the layer’s y position should animate down by comp height.
    If there is no layer marker, the layer should stay on it’s current value.
    I’m assuming there will be only 1 layer marker.
    After a lot of searching in forums I think it could be possible to accomplish?
    I have tried with modifying an expression written by Dan Ebberts in the forum here, but I can’t make it work as it should.
    Testing with marker named UP or DOWN it only moves the layer down, not up.
    Could anybody check where the mistake could be? Thanks in advance!
    Eva
    I came up with this:
    moveFrames = 20;
    try{
    m = thisLayer.marker.key("UP");
    }catch(err){
    m = null;
    if (m != null && time > m.time){
    t = time - m.time;
    dur = framesToTime(moveFrames);
    y = ease(t,0,dur,value[1],value[1]-height);
    [value[0],y]
    else
    try{
    m = thisLayer.marker.key("DOWN");
    }catch(err){
    m = null;
    t = time - m.time;
    y = ease(t,0,dur,value[1],value[1]+height);
    [value[0],y]
    else
    value
    Eva Lepik replied 9 years, 4 months ago 2 Members · 2 Replies
  • Steve Sierra
    May 1, 2017 at 2:31 pm
    I think you just forgot the curly parenthesis for your else statements :
    moveFrames = 20;
    try{
    m = thisLayer.marker.key(“UP”);
    }catch(err){
    m = null;
    t = time – m.time;
    [value[0],y]
    else{ //———-HERE———————–
    try{
    m = thisLayer.marker.key(“DOWN”);
    }catch(err){
    m = null;
    t = time – m.time;
    [value[0],y]
    else
    value
    }//———–AND HERE——————-
    Cheers !
  • Eva Lepik
    May 1, 2017 at 2:40 pm
    Thank you, Steve!
    That’s awesome :))
    I wouldn’t have found the error myself, as I ‘m just starting out with conditional expressions.
    Regards,
    Eva
